Discussion topic: Fault
This message was authored by: Rachael2915
Message posted on 18 Dec 2023 01:33 PM
Fault
Both sky boxes are saying technical fault
Find out more
Message posted on 18 Dec 2023 01:41 PM
Re: Fault
hi @Rachael2915
May I suggest the first thing to try is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on the mini box.
