Discussion topic: Fault with both sky boxes
Message posted on 23 Aug 2025 10:14 AM
Hi, can anyone help me get through to Sky to report a series of faults with both my sky boxes that doesn’t fit with any of the online options, I tried the virtual assistant but that didn’t help either
Message posted on 23 Aug 2025 12:42 PM
Re: Fault with both sky boxes
@K-S what faults are you having perhaps we in the forum can help you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 23 Aug 2025 08:50 PM
Sky is lagging, it's slow, often doesn't connect, recordings fail and I get can't connect to sky box messages. We can't even watch live tv without an issue
Message posted on 23 Aug 2025 09:44 PM
@K-S The first thing to trey is rebooting your main Q box ie
Message posted on 24 Aug 2025 06:47 AM
Hi thanks, yeah I've tried that twice now but not working. It actually worse since the second time I tried it. Just getting so frustrated that I can't get through to anyone to help 😕
Message posted on 24 Aug 2025 07:48 AM
I would abandon all hope of keeping any recordings and try two things;
Factory reset in the installer menu
If that doesn't work, box troubleshooter on sky's site until it gives up and gets a box replacement organised. Make sure you keep your viewing card and do not keep the power cable (they aren't all the same)
Message posted on 24 Aug 2025 11:45 AM
@K-S before trying a factory reset You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
Message posted on 24 Aug 2025 02:11 PM
Thank you so much, tried that but unfortunately hasn't fixed it 😢
Message posted on 24 Aug 2025 02:30 PM
@K-S wrote:Thank you so much, tried that but unfortunately hasn't fixed it 😢
Who are you replying to? If you don't hit the quite button to include their post, this forum doesn't give any indication (unfortunately)
Message posted on 24 Aug 2025 03:28 PM
@Chodley So sorry I was replying to @Laing1 I'm guessing I will have to do the full factory reset 🙈
Message posted on 24 Aug 2025 04:09 PM
@K-S If a full factory reset as advised by @Chodley doesn't help as he suggested it could be a hard drive probem
by following the link below it will lead you to ordering a new box.
Message posted on 24 Aug 2025 06:31 PM
Message posted on 24 Aug 2025 07:30 PM
@K-S wrote:@Laing1 @Chodley thank you both so much for your help. Given the amount I pay Sky each month it's crazy that I have to get help through a forum but I appreciate it all the same..
It's crazy that given how much we all pay Sky they are still losing money (224m in 2024) but they do have OpEx of over £10Bn per year so they'll clearly look everywhere to try to save cost.
