Discussion topic: Fan on sky Q box constantly on
This message was authored by: David999
For rhe last few weeks on a Sunday the fan starts running and the only way to stop it is to disconnect the power and leave it for 10-15 minutes then re start is this a problem with the box as it doesn't appear to be overheating?
This message was authored by: Stephen+Mourton
Re: Fan on sky Q box constantly on
@David999   Can the Sky box 'breath' in other words is it enclosed or other objects right next to it?  I does need a bit of space around it to stay at the best temperature.
This message was authored by: skinbags
The box its sited on a unit with nothing around it to prevent overheating
this problem has only arisen since i had a  vist from an engineer who replaced the box i had been using for years
@David999  Well I thought it worth a try.  As no one else on the forum has come up with another idea it sounds like a problem that only an engineer can sort out, so I would suggest giving Sky a ring.  I hope you sort it soon.
Hi @David999 as the SKYQ box doesn't seem to be hot to the touch, the fan is obviously cooling the electronics in the box suggesting that the QBox is doing multiple tasks, such as housekeeping, whilst recording any scheduled programmes etc.
If the fan stops after a while then all is fine.
If it continues for longer than 30min and the case becomes too hot to touch then power down, and wait for it to cool, then call SKY and talk to an advisor about replacing the box?
I have let it run for over an hour before disconnecting the box is still cool top and bottom
i leave it for 15 mins reconnect the power fan runs the slows in dtages till it stops then its fine for a week?
This message was authored by: Bobpants75
Unplug the network cable from the sky box and connect sky to your router via wifi. If that works, then you can reconnect the router to the sky box, but thorugh an old 10/100MB switch. It's ridiculous but it worked for me... I had 5 boxes before I worked this out.
@Bobpants75
You have added to a thread that's 12 months old. Hopefully the issue has been resolved by now.
I think it's worth having this suggestion show up in search too though, even if this specific box got somehow resolved.
This message was authored by: NoName
My box ran hot for a while - I ended up putting a large heatsink on the back left of the box (outside obviously, but a 3 inch by 6 inch by 3 inch high heatsink from an old power amp), which also incidentally solved a high pitch whine the box was making. Its over the place the satellite connections come in, and has solved both problems - heat and noise, and the fan hardly ever runs now.
