This discussion topic has been answered Discussion topic: Failure
Message posted on 14 Jan 2026 04:14 PM
Connection continually failed between Q and Mini Box
Message posted on 14 Jan 2026 04:38 PM
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
If you haven’t done it already it may be worth rebooting your broadband hub, then the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 14 Jan 2026 04:17 PM
Re: Failure
I need a Sky Engineer
