Discussion topic: Failed/part recordings
Message posted on 02 Aug 2024 02:03 PM
Hi knowledgeable people.
We recently had a new SkyQ box after our old one gave up. With this new box it's refusing to record anything in MTV showing "part recorded no subscription" or "failed to record". I've spoken to Sky twice who have reset the box, updated software etc but it's still happening. It sometimes happens with other channels also. I'm tearing my hair out - any suggestions please?
Message posted on 02 Aug 2024 05:53 PM
Re: Failed/part recordings
Hi @Michele01
Have you tried a Reset Settings in the Q box hidden menu.
Message posted on 02 Aug 2024 06:56 PM
Thank you so much. I'll try this later. Appreciate your help.
