Discussion topic: Factory reset problem
This message was authored by: DM26
I tried to do a factory reset yesterday and now my box won't responding to my remote
Re: Factory reset problem
hi @DM26
It will need a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
