Discussion topic: Factory reset help needed
Message posted on 16 Dec 2023 06:13 PM
I pressed factory reset and now I can't access anything including the plain blue screen! It constantly says No signal HDMI and to check the cable connection (done) and press source on your remote (nothing happens) Can anyone help?
Message posted on 16 Dec 2023 07:37 PM
Re: Factory reset help needed
Hi @NMDurham
Have you tried using your TV Set remote to cycle through the HDMI Inputs to find the one connected to the Q box.
Once you find which one it is reboot your Q box.
Then Try completly resetting your Bluetooth remote.
