9
This discussion topic has been answered Discussion topic: Extension cably
This message was authored by: Simpsono4
Extension cably
We have moved our television and require an extension cable about 4 metres long it's the pink and black lead. Can you advise if this is available please
This message was authored by: nigea99 Answer
Re: Extension cably
@Chodley wrote:
HDMI at 4k HDR is ok up to about 10 metres so you should be ok.
e.g. https://amzn.eu/d/5IXR2Ju
We don't really recoomend 4K/HDR over 3m (5m possibly at a push) for normal (non optical) cables
Avatar for Simpsono4
Re: Extension cably
Re: Extension cably
If that's the HDMI lead then you would need to source your own cable.
Re: Extension cably
Re: Extension cably
Re: Extension cably
I've run 4k 8bit 50Hz at over 10m on an 18Gb certified cable and it was fine. Not tried 10bit yet but in theory...
Re: Extension cably
From SKY Q or other device  ?
SKY Q seems to be  quite sensitive  to longer lengths (hence our recommendation)
Re: Extension cably
Erm. I can't remember which source I used now! I'm going to dig the cable out and test the Q at 10bit...
Re: Extension cably
 Seems fine
but I'm going to watch the whole movie to see if it twitches
Re: Extension cably
Yeah the whole movie (Mario Bros,
not bad considering, 7/10 for Nintendo fans) worked without a hiccup.
