Discussion topic: Excessive colour saturation
Message posted on 24 Apr 2023 03:03 PM
Just had to reconnect my tv equipment and for some reason I have been left with excessive colour saturation when viewing through our Sky Q box, if I switch to the Sony TV,s own settings the picture is fine. Is there any way of reducing colour saturation on the Sky remote,as I can't find a way, thanks.
Message posted on 24 Apr 2023 03:20 PM - last edited: 24 Apr 2023 03:21 PM
Re: Excessive colour saturation
@Blackbird1956 wrote:Just had to reconnect my tv equipment and for some reason I have been left with excessive colour saturation when viewing through our Sky Q box, if I switch to the Sony TV,s own settings the picture is fine. Is there any way of reducing colour saturation on the Sky remote,as I can't find a way, thanks.
Sky Q has no picture output settings of its own other than resolution and 8bit or 10bit colour depth.
When you reconnected your box did you connect it to the same HDMI port on your TV that it was in before?
