Discussion topic: Exaited picture on sky Q
This message was authored by: Dobber1234
Hello, I recently got a new SkyQ box in stock and when I go away from the TV for an hour and switch it off and then come back to it. The picture is all pixelated. It's basically white pixels all over the screen so I have to do a complete res system set of my TV itself and then the picture returns to normal. Does anyone know if this keeps happening is it an issue with my TV or is it an issue with the HDMI cable? I will be grateful if someone could help thank you.
Derek O’Brien sky customer since 2006 and love sky Q it should be kept at all costs
Re: Exaited picture on sky Q
@Dobber1234 not something i've heard of before but You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
