Discussion topic: Every time I try to record, it says I need to upgrade. The sky, said it should be part of my package
Message posted on 12 Aug 2023 10:02 AM
Every time I record on my box, it says I need to upgrade, but sky said I don't need upgrade to record
Message posted on 12 Aug 2023 11:18 AM
Re: Every time I try to record, it says I need to upgrade. The sky, said it should be part of my pac
hi @Djcammy5
Do you reallly mean recording (i.e. set a recording from a Satellite channel as it is broadcast) or do you mean download something from On demand or Catch up etc. ?
If the latter then there are a couple of known problems that could be affecting you.
One can be sorted with a simple Setting change :
Do you have the HD add on - if not please try changing the default download preference to SD in
Main Menu -> Settings -> Setup -> Preferences
If you do have the HD add on or the above does not sort you please let us know so we can escalate to SKY
