Discussion topic: Error message saying no satellite signalError message saying no satellite signal
This message was authored by: Top-cat
Re: Error message saying no satellite signalError message saying no satellite signal
@Top-cat
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️ a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News).
▪️following adverse weather wait times for an engineer will probably be significantly longer
