Discussion topic: Error code AMP1003 sky sports plus stream
Message posted on 21 Jan 2025 08:27 PM
Trying to watch EFL stream on SS+ but error code: AMP1003 continues to show up. Stream is working fine via sky sports app on my phone but want to watch on tv
Message posted on 21 Jan 2025 08:58 PM
Sky sports + error AMP1003 told to retry what a load of rubbish it is
Get error told retry great
Message posted on 21 Jan 2025 09:15 PM - last edited: 21 Jan 2025 09:16 PM
Re: Sky sports + error AMP1003 told to retry what a load of rubbish it is
What platform are you seeing this on, Sky Q or Sky Stream/Glass?
You have posted this in the mobile apps section. Not seen this error that I can recall on the mobile Sky Sports app.
If you do have Sky Q or Sky Glass/Stream:
For Sky Q - Often this error is cured by removing the power for 30 seconds on Sky Q.
For Sky Glass/Stream try a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
If neither of those cure it, try refreshing your apps, as described here:
On Sky Q:
- Press Home on your Sky Q remote, then highlight Settings
- Press 0,0,1 and Select to access the Installer menu
- Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing. The refresh can take 24 hours to complete.
On Sky Glass or a Sky Stream puck:
- Press Home on your Sky remote, then select Settings
- Press System management then Resets and updates and finally Refresh apps.
- You'll see a message that says, 'Your apps are being refreshed'.
Message posted on 21 Jan 2025 09:42 PM
Sky Glass Sky Sports + Football Matches
Message posted on 21 Jan 2025 09:44 PM
Re: Error code AMP1003 sky sports plus stream
Same issue for me. What's going on Sky?,
Message posted on 22 Jan 2025 03:01 PM
Anyone have any other thoughts as I have tried the recommendations?
