Discussion topic: Error MR106
This message was authored by: Gillian88
Error MR106
I am getting an error MR106 on my mini box and can't get past the message your sky q mini box has not been able to connect to an activation server
Re: Error MR106
Hi @Gillian88
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
