Discussion topic: Error MR 104
This message was authored by: JClark1981
Error MR 104
My main tv connected to main sky q box is working, but the sky q mini boxes are not. Showing there is a problem finding them in the network. Error MR 104.
can anyone help?
Re: Error MR 104
can anyone help?
Hi @JClark1981
Reboot the mini as above.
