Discussion topic: English commentary
This message was authored by: Clare20241
English commentary
How do you get English commentary when it is available on S4C
Re: English commentary
hi @Clare20241
This may seem totally counter-intuitive but the solution is to select Welsh as the language
Settings - Setup - Audio Visual - Audio Language
Then when English is available you will get English commentary
Avatar for Clare20241
We have tried this before but it does not seem to work
@Clare20241
S4C says
Accessing English language commentary - Sky Q
Press the Home Button on the remote
Scroll down using the arrow buttons to Settings press the centre button to select it.
Scroll to Set Up and press the centre button to select it.
Scroll to Preferences and select Go to Audio Language press the centre button and change it from English to Welsh, also make sure Audio Description is set to off.
This will ensure you have English language commentary on S4C when it is available automatically.
When English commentary is available press the red button then select it from the onscreen graphics.
Although I don;t watch S4C other than to check this it has always worked when I checked.
Also history on here would also confirm this works for others too
I watched the Wales - Montenegro game last night and got English commentary by selecting the Red Button as prompted on-screen. The mini menu that appeared was in Welsh, so I've no idea which option switched it to English, but one of them did
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
