Discussion topic: Engineer
This message was authored by: Fiona266
Engineer
I have lost access to about 6 channels, although subscribed to. I am wheelchair bound, and live with my elderly father, and really need to have an engineer to come and sort it. I cannot find a way to easily book a visit HELP!
Re: Engineer
@Fiona266
Any error message displayed such at 'no satellite signal'?
Avatar for Fiona266
Re: Engineer
The channel is currently affected by a problem with your satellite signal.
i have it on about 4 different channels.
being in a wheelchair, I can't move around to sort anything out and my dad is 85.  I have Sky Protect, and would really welcome an engineer to come and sort it for us.
Re: Engineer
@Fiona266
You aren’t contacting Sky Customer Services here. This is predominantly a customer led discussion forum where Sky customers are available to help other customers.
No signal and no satellite signal issues are different .
If you’re seeing a “no satellite signal” message perhaps get a family member or friend to check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
