Discussion topic: Elderly customer
This message was authored by: Betty999999
Elderly customer
Is there a direct number and elderly customer can speak with someone.? Too complicated for them you jump through technical hoops. They are upset
Re: Elderly customer
@Betty999999
If they have health issues that amongst other things may affect the ability to communicate, it may be worth registering with the Sky Accessibility Team who may be able to help now or in the future. Once registered there are also different methods of communication with this team other than phoning so have a look at these related links… ~
https://www.skyaccessibility.sky/
https://www.sky.com/help/articles/accessibility-information-sky-mobile-broadband-and-talk-customers
https://www.sky.com/help/articles/third-party-assistance
Otherwise, the current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟦 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟦 online help via this link
🟦 Sky Assistant 💬 should also be available via
🟦 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
@Betty999999
Thete is no specialist number but if you reply about your issue on here then perhaps we can help you ?
