Discussion topic: Dull screen
This message was authored by: AdieA
Dull screen
Just bought a new TV which is fine but anytime I connect sky the screen looks very dull as if there is something covering it. I've tried changing brightness contrast etc but nothing seems to work until I come off Sky then screen looks great. Is there a fix?
Re: Dull screen
Hi @AdieA   We can only suggest things to try if you tell us the make and model of the TV and what resolution you have set on the Sky Q box. Do you have a Sky HD subscription? Are you using the Sky Q supplied HDMI lead which is correctly seated both ends.
Re: Dull screen
What output video resolution is the Q set to?
