Discussion topic: Dramatic I know but feel like crying I’m so frustrated.
Message posted on 21 Apr 2026 06:10 PM
Will try and be brief. I cannot connect my Q minibox. It says no satellite. It tells me it's my tv but I know it's not. I've had varying messages ranging from no satellite to check your cable indicating there is a cable issue. I also notice on the sky wall socket close to my main hub whereas there are usually 4 solid green lights there are now only 3. The second one in from the left isn't on, what is this indicating. I can't be the only k e who feels the online instructions are at times extremely frustrating to navigate. It would be so nice to reason with a human to help trouble shoot and not a bot,
Message posted on 21 Apr 2026 06:12 PM
Re: Dramatic I know but feel like crying I’m so frustrated.
@Reggieboy2 not sure what you have tried if anything
but
Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Apr 2026 06:22 PM
Yea I've tried all the turn it off and turn it on reboot countless times. There are still only 3 green light on the sky socket. I remember when the engineer installed it in Dec he mentioned there should always be 4 solid green lights. So should I be calling an engineer at this point to fix the issue
Message posted on 21 Apr 2026 09:14 PM - last edited: 21 Apr 2026 09:14 PM
Well, the cable (not the one to the internet, the one from the dish) carries the satellite signal so those two messages do go hand-in-hand
Which sky wallbox is it? The full fibre ONT?
