18
This discussion topic has been answered Discussion topic: Downloading next episode issue, and New Series Issue.
This message was authored by: Mark.Seddon
I have noticed that when I go to download a next episode,  it freezes on 100% downloaded.
But I have also noticed, that if I don't check it when it's fully downloaded, it will go up to 101%.
I have taken pictures of this issue, so that if people respond with the same issue.  Sky can have a look at this issue.
As I noticed the same issue about 5 months ago, when I was having an issue with it splitting my recordings, and putting them all over my recordings folder.
They found that there was an issue with the coding of the update that made this problem.  So I think this could be another coding issue.
I have also noticed in the TV Guide, New Series.  That their is 4 boxes for the same show.  I have taken pictures of this issue, so if anyone in the community are seeing this same problem can comment. 
Avatar for Mark.Seddon
Level 2 icon
This message was authored by: Mark.Seddon Answer
Re: Downloading next episode issue, and New Series Issue.
Hi Tom,
It's already been escalated to the back tech team via Sky Accessibility.
The reason for my post here, was to see if others were having these same issues, then I know and Sky will know its part of a bigger issue.
This message was authored by: Tom-W19
Hi @Mark.Seddon
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Level 2 icon
Hi Tom,
This message was authored by: Kayfersmum31
Hi @Mark.Seddon
I'm having the same 101% downloading issue. Were you able to find a suitable resolution?
Sam
Level 2 icon
Hi Sam,
No, unfortunately I haven't found a resolution yet, but I contacted Sky Accessiblity the other day.
They've past it onto the technical department to work on a fix for the issue.
I thought I'd bring it to the community because the more people who have this issue.   The harder they'll work on a fix.
It only started playing up 2 weeks ago, when they sent through the new update.  So I'm thinking it's something to do with the coding of the new software update.
There was no Software update a few weeks ago @Mark.Seddon
Last one was months ago.
If it was a software issue it would affect all boxes.
@Mark.Seddon @Kayfersmum31 you could try deleting the download that has gone stupid then ndeleting it from the deleted section then rebooting your box and finally downloading it again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Lisa-P1987
We are still looking to help you @Mark.Seddon . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Level 2 icon
Hi Lisa,
It's already been escalated.  Like I said above I put it up here to see how many others are having the same issue.  Then you can see its not only myself with this issue.
This message was authored by: ChrisG
Did you ever get a fix for this. Were new to sky and having the same issue.
This message was authored by: SteveD+Newbury
I'm having the same issue
This message was authored by: Key41
I've just had this problem, I went to manage my recordings and I was at 99, I deleted some old recordings and it's all sorted.
I think my Q box is going. Press SKY or power on remote, doesn't come on. Have to press button on box, off and then on. New batteries in remote. Also, I still press to download and it does nothing. I leave it for a while, it says x downloaded but never actually downloads. I have the warranty, think I'll speak to them.
This message was authored by: Derek66
Hi Mark, we have exactly the same problems as you
Derek just go to recordings, at the bottom of the list is manage, just delete some previous recordings and it'll sort it
