Discussion topic: Downloading in Ultra HD
This message was authored by: Jasper2344
Hi all,
After downloading an episode of a program or a movie during play back the sound cuts out for a coupke of seconds the its fine. Usually does this 2-4 times depending on the program length. Any ideas on how i can solve this? Many thanks.
This message was authored by: Mister_Dalek
Re: Downloading in Ultra HD
@Jasper2344 wrote:
Hi all,
Are the drop-outs repeatable, as in, if you rewind and play back the same section does it drop out in the same place? If this is the case then you could try fully deleting the download from your box and trying a new download. If this exhibits the same problem then it'll be worth notifying Viewer Relations as it's probably a problem with the encoding of the original file.
You can email them here: [email protected]
