Discussion topic: Dog ate Sky Q Remote
Message posted on 24 Apr 2023 07:54 PM
Hi, dog chewed up Sky Q remote so can't unpair it. How can I use a new remote without unpairing the old one please?
Message posted on 24 Apr 2023 07:58 PM - last edited: 24 Apr 2023 07:58 PM
Re: Dog ate Sky Q Remote
hi @LillyT12
you don't need to unpair the old remote
The new remote will pair with the SKY Q box, replacing the old one
Just press hold 1 & 3 on the new remote to start the process
This doesn't seem to be working for some reason!
Message posted on 24 Apr 2023 08:00 PM - last edited: 24 Apr 2023 08:01 PM
In which case try resetting the new remote
Press & hold 6 & 9 together until the red led above the SKY logo button flashes 4 times
Once reset try the 1 & 3 again
note : Until it is paired it needs direct line of sight of the Q box as it uses infrared until it is paired
