Discussion topic: Distorted
This message was authored by: Justjack72
Distorted
Have had bother with loss off signal last 4 days now got it all fix but the picture keeps distorting when watching, could it be my aerials?
Re: Distorted
@Justjack72
Sky Q doesn't rely on aerials.
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
