Discussion topic: Distorted sound on new sky q box
Message posted on 23 Apr 2025 09:21 AM
Hello
i I had a new sky box installed a few weeks back and my sounds is distorted when on channels. So for example I may be watching a channel, if I switch, it goes into a stutter/shudders in slow motion and sometimes it corrects itself after a few mins or I have to change channels a few times and come back so it works again. The same applies to recordings where I have to stop playing, go back out and come back into work. Had a previous sky Q box and worked for many years with no problems on same TV and sound bar (returned to sky last month with a new box installed) . Any help will be greatly appreciated
Message posted on 23 Apr 2025 09:52 AM
Re: Distorted sound on new sky q box
@NeilDab wrote:
Hello
Hi @NeilDab
Message posted on 23 Apr 2025 10:19 AM
Thank you. Just done this and will see how the day goes and whether this makes a difference.
