Discussion topic: Disney+ permanent buffering wheel issues
Message posted on 21 Sep 2023 12:43 PM
Hi, I have an issue with the Disney+ app on Sky Q. Sometimes the buffering wheel will appear in the middle of the screen and spin constantly even when the content is playing fine behind it. The fast forward and rewind functions do not work when the buffer wheel in spinning so as well as being distracting it is also restrictive. This seems to happen more when resuming a programme half way through than when starting a new one. The only way to stop it happening seems to be a full restart of the Sky box and the TV.
Oddly, I also have the disney+ app through the android OS on my smart tv which sky is plugged in to and it never has this problem, it's only through the sky version of the app.
Message posted on 21 Sep 2023 01:25 PM
Re: Disney+ permanent buffering wheel issues
Hi @vb86
Try a Reset Settings in the Q box hidden menu. See if this helps
