Discussion topic: Disney Sky Q
Message posted on 29 May 2025 08:59 PM
Disney Sky Q
Message posted on 29 May 2025 09:06 PM
Re: Disney Sky Q
@Dean+pirks wrote:
Everytime I am on Disney + it buffers and then the screen goes blank. I can't watch anything on Disney + on sky Q it ruins the viewing. Is there a fix for this i have tried logging in and out and turning the box on and off again. It really is annoying. Many thanks
Hi @Dean+pirks
Try a Reset Settings in the Q box hidden menu. See if that improves the issue.
