Discussion topic: Dish move
Message posted on 29 Jan 2026 09:27 AM
Dish move
I need to move my sky dish as I'm moving my television from one side of the room to the other
Message posted on 29 Jan 2026 09:46 AM
Re: Dish move
hi @Marion1975
Just to let you know you are not contacting SKY customer services here - primarily just other customers.
Although it may not work for you (or be less ideal) but you can get Satellite Extension cables from a few sources.
Alternatively you can contact SKY - See below who are likely to charge around £65 or it may be quicker and/or cheaper to use a local Satellite installer
I believe these are the current methods for contacting Sky. Depending on your reason for making contact some methods are more appropriate than others …
call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
online help via this link
https://www.sky.com/help
At the end of the help it MAY provide a phone number if it's appropriate.
Sky Assistant is now available at the top of sky.com/help (or as a chat bubble bottom right if used before) for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Message posted on 29 Jan 2026 11:37 AM
Re: Dish move
Just to add that the dish may not be able to be moved if an alternative location for it can't be found.
