Discussion topic: Different
Message posted on 01 Mar 2026 03:00 PM
Different
Different Power Socket to previous Q box. So can't plug in.
why o why have they (sky) changed to Power Socket when the existing one is different.
Sky was a good company to work with be I fear it has gone downhill.
Get to talk to someone and not a robot is not possible.
Martin M
Message posted on 01 Mar 2026 03:13 PM - last edited: 01 Mar 2026 03:14 PM
Re: Different
Hi @Mart40 Unfortunately this is well known in the community, the advise has always been, make sure you keep the viewing card and swap the power lead with the box. It does mean another box swap as they don't just swap the power leads. I will escalate your post to the messaging team.
Message posted on 01 Mar 2026 03:16 PM
Re: Different
@Mart40 wrote:Different Power Socket to previous Q box. So can't plug in.
Martin M
I presume you mean the power socket on the box that you put the mains lead in. Did your replacement box not come with a mains lead? It should have done and would match the socket of replacement box. If you did not get one you need to contact Sky to sort itout if you ring and get the amotive service ( the robot) just answer the questions and at the end of what ever they suggest, just ignore and then when it ask you it that all or words to that effect say "no" and you will be put thoughto a human adviser.
