4
This discussion topic has been answered Discussion topic: Deleting recording mid viewing
This message was authored by: Daveliou
Is there a way to delete a recording mid way, or without having to watch the recording right to the end .  On Sky Plus, you just used to press the yellow button and it deleted it
Re: Deleting recording mid viewing
@Daveliou
You can't delete it whilst still viewing it if that's what you mean. Press dismiss then delete in the normal way. You don't have to fast forward it to the end either.
Hi @Daveliou if you go into Recordings and click once on the programme you want to delete, the delete button will show underneath the programme start box?
Avatar for Daveliou
Good morning @Quoman7  and thank you for your response 🙂
What I am trying to find out is if whilst watching a recording and I decide to immediately delete the recording (whilst watching), is there a quick way to delete instead of winding the recording to the end in order to delete; or as you say, come out completely to delete.
@Daveliou
Hi @Daveliou
You make have  to press the Dismiss button (left of Home button) twice to exit the recording
