This discussion topic has been answered Discussion topic: Deleted items not showing in managed
Message posted on 22 Aug 2026 11:59 AM - last edited: 22 Aug 2026 12:19 PM
I accidentally deleted something I recorded and usually if that happens it's in the "manage" items and you can undelete it.
However, it is not there and I tested it by deleting something else and the same thing has happened. So basically none of my deleted shows are showing under "manage" What can I do to clear this please?
Also, I can't pause or rewind live TV, not sure if it's connected?
Message posted on 22 Aug 2026 12:43 PM
Try the troubleshooting on this link which should be relevant for Glass, Stream and Sky Q...
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 22 Aug 2026 12:23 PM
Re: Deleted items not showing in managed
Hi @Grats1
Is the Deleted section in Manage completely empty?
Also
Have you tried rebooting your Q box?
Message posted on 22 Aug 2026 12:41 PM
Hiya yes the Deleted under Manage is totally empty
I have tried to reboot yes exactly as you describe (sorry should have added that!)
What I've also just realised is I can't play the recording either.... And being very dim have just noticed that they're all "technical fault" so recording failed....So actually the programme had not recorded!
I'm downloading the ones that failed and just testing a program recording now
Apologies I'm very tired so missed all that.. late night back from football all started this by deleting the game! Will close this off. Thanks for your help!
Message posted on 23 Aug 2026 12:45 AM
@Grats1 wrote:Hiya yes the Deleted under Manage is totally empty
Hope you got it sorted.
As far as I know, if a recording was "failed" (for any reason - eg "powercut" I've had when my box was unplugged during the scheduled times of a recording) then deleting it doesn't add an entry to the list in Managed, as there is no recording which could be un-deleted. I think this is what you were saying you'd realised.
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
