Discussion topic: Delay in Sky Q Mini box responding to remote
This message was authored by david123654 This message was authored by: david123654
Delay in Sky Q Mini box responding to remote. Sometimes immediate. Sometimes 10 seconds later. Sometimes never responds. Definitely the box as remote works ok on other mini boxes in house
Re: Delay in Sky Q Mini box responding to remote
Hi @david123654
Try a reset settings in the mini box hidden menu.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
