5
This discussion topic has been answered Discussion topic: Controlling hidden Sky Q box
This message was authored by: Chloe+Mo
Hi all,
Wondered if anyone has found a solution to the below?
We have a sky Q box that lives in the living room and it sticks out like a sore thumb so want to hide it in the playroom behind the living room through a brick wall.
The magic eye doesn't work with Sky Q so what can I use to send a signal from the living room to the Sky box in the play room?
Many thanks
Re: Controlling hidden Sky Q box
@Chloe+Mo wrote:
Hi oldfella,
The remote will still work through a wall?
Yes @Chloe+Mo
Assuming it is a Bluetooth remote (with Microphone button) it will
@Chloe+Mo wrote:
Hi all,
Many thanks
Hi @Chloe+Mo
Your existing Bluetooth remote should work if correctly paired to your Q box
Avatar for Chloe+Mo
Hi oldfella,
@Chloe+Mo wrote:
Hi oldfella,
Yes @Chloe+Mo
@Chloe+Mo wrote:
Hi oldfella,
hi @Chloe+Mo
As @oldfella  says yes when the remote is paired via bluetooth.
As a test I have used my  remote in my back garden with my box located in an alcove in my front  lounge near the front window, so through 2 walls and rooms.
Avatar for Chloe+Mo
Hi both,
thank you for the help.
That seems to wor. Tried controlling sky from playroom and channels changed.
Great.
