Discussion topic: Controlling Sky Q with Harmony Remote/Hub
This message was authored by: reddwarfcrew
Hi, I have Sky Q and have been happily controllinh it using Alex via a harmony hub.
However, it's now stopped working.  I've tried re-adding the Sky Q as a new device in the harmony hub but no commands work anymore however I try to use it (alexa/software remote/hardware remote).
Anyone experience similar.  Any ideas?
It should still be supported as I can see poeple successfully config'ing a harmonoy for sky stream.
Thanks.
Sky Q 2TB UHD, 3 Sky Minis, Sky Gigafast SR203.
Re: Controlling Sky Q with Harmony Remote/Hub
Hi @reddwarfcrew
I am sorry to say it must be something local to you. I am using a Harmony Hub 100% of the time controlling my Sky Q mainly with an Elite remote, but works fine with Alexa.
I can only suggest the obvious things like reboot everything starting with your broadband router. Does the green light flash on the Hub, showing it is receiving the commands.
Avatar for reddwarfcrew
Level 4 icon
hmm, so after playing for the last hour i found that the signal wasnt getting to the Sky Q anymore.
Open the 'IR friendly' glass cabinet door and it worked.... albeit a bit tempromental.
I've now put in the IR Blaster and all is fine.  So either the harmony is emitting a weaker signal, the sky q requires a stronger signal then before or something is interfering with the signal. All a bit odd, but seems to be okay now.
