5
This discussion topic has been answered Discussion topic: Control JVC TV
This message was authored by: Simonh12023
Control JVC TV
I have just bought a JVC LT-40CR330 but can't get my mini box remote to work it.
Avatar for Simonh12023
This message was authored by: Simonh12023 Answer
Re: Control JVC TV
Sorted it, tried some other 'oddball' manufacturers and Polaroid worked 👍
Re: Control JVC TV
You've done a remote reset presumably?
Re: Control JVC TV
Yes and tried all the JVC models in the JVC list and tried the find it for me which it tries 25 codes.
Re: Control JVC TV
@Simonh12023 try the Vestel codes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Control JVC TV
Re: Control JVC TV
Probably all made in the same factory. Quite sad seeing these once big brands just used as badges.
