Discussion topic: Contrast keeps changing by itself
Message posted on 01 Oct 2023 11:07 AM
Contrast changes by its self when changing source.
Message posted on 01 Oct 2023 11:10 AM
Re: Contrast keeps changing by itself
Message posted on 01 Oct 2023 11:24 AM
@renowned+joinery wrote:Contrast changes by its self when changing source.
Sounds like your TV settings rather than the Q box?
