Discussion topic: Continual problems with sky q mini boxes
Message posted on 26 Dec 2025 05:14 PM
I have 3 sky q mini boxes they will work (relatively) fine for months on end and then all of a sudden on a day like today - with absolutely nothing changing with our home setup - they will simply stop functioning. They switch between can't connect to sky box, then not being able to connect to the internet, then back again, seemingly at random.
Its infuriating. today is boxing day 2025 and we're trying to chill out and watch movies upstairs but for the past hour I've been up and down the stairs like an **bleep**ole, continually resetting and re-booting everything, trying to get a connection to hold.
Q1. anyone else ever experience anything like this?
Q2. Are there any realistically valuable alternatives to the mini boxes? they are becoming more hassle than they are worth.
During the course of writing this post the sky mini box in front of me has gained and lost connectoin 4 times.
I will repeat, absolutely nothing has changed with our home setup.
Message posted on 26 Dec 2025 05:23 PM
Re: Continual problems with sky q mini boxes
Hi @Mickc79
Don't know exactly what you have tried.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 26 Dec 2025 05:25 PM - last edited: 26 Dec 2025 07:05 PM
a) Sky Go app on Apple TV boxes, consoles or computer with HDMI output (covered by the existing Q Multiscreen subscription)
b) NowTV on appropriate host hardware (needs separate subscription but can run alongside Q)
c) Sky Stream pucks (which requires giving up Q entirely)
Message posted on 26 Dec 2025 05:29 PM
Thanks. I'm gonna try running an hdmi from my iPad and using sky go.
Message posted on 26 Dec 2025 05:30 PM
Appreciate your reply but I've tried all of that more than once.
it seems extremely erratic. Reboot everything as per official guidelines and you get it working for 5 minutes then it drops again.
madness.
Message posted on 26 Dec 2025 06:59 PM - last edited: 26 Dec 2025 07:01 PM
HDMI output from phone or tablet won't work with Sky Go even if the hardware supports it for other apps: that's why I said computer (Windows or OSX, desktop or laptop)
