Discussion topic: Contacting Sky
This message was authored by: Nick265
Contacting Sky
I've renewed my TV & Broadband subscription this afternoon and the confirmation email is different to what I agreed over the phone.
The broadband package I ordered was the full fibre 500. The confirmation email is showing full fibre 150.
I've spent over 2 hours trying to find a phone number to rectify this issue, can someone help.
Re: Contacting Sky
@Nick265
These are the current methods for contacting Sky. Some methods will be more appropriate than others depending on the reason for contact……
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
