4
This discussion topic has been answered Discussion topic: Connectivity
This message was authored by: royalbengal
Connectivity
Sky Q box struggles to come back on, constantly having to reset or turn off, very slow through menus, and currently can't find my recordings.
all settings say good signal and wifi ok, but have very similar problems with our mini box upstairs. This goes on and off constantly even when reset, and re connected to sky Q box downstairs
Re: Connectivity
Hi @royalbengal
Try a Reset Settings in the main Q box hidden menu.
Re: Connectivity
Hi @royalbengal
Avatar for royalbengal
Re: Connectivity
Thanks, that appears to have worked
it is working very slow, and my recordings took a long time to load up 'please wait' for at least 5 minutes.
when you change channels, it can take about 10 seconds to change over which is strange!
The mini box upstairs can sometimes lose connectivity and has been doing it a lot recently.
we have had both boxes several years now, over 5 years, I wondered whether it is time to replace?
This message was authored by: BustaW
Re: Connectivity
I have followed the instructions but dtill
no network connection
This message was authored by: Leenew24
Re: Connectivity
I have followed all the steps but still not connecting to the Internet and signal says its working and can't get a contact number to speak to someone
