Discussion topic: Connectivity problem with mini boxes
This message was authored by: stum1980
So I've hit a brick wall on ideas! All help appreciated!
All mini-boxes (hardwired) are displaying no satelilte signal, conectivity issue with main box (or similar message). However, they are all saying they are connected to the main box and have internet. I'm able to use the apps, Netflix, youtube etc. from the miniboxes fine, I just can't watch TV. I can however watch TV normally on the main box.
So far I've tried:
Rebooting main Sky Q box
Rebooting mini boxes
Reactivating mini boxes locally
Reactivating mini boxes via main box
Forced software update on mini box
Rebooting all internet connectivity, switches, routers etc.
Any other ideas as to what to try?
Re: Connectivity problem with mini boxes
So far I've tried:
@stum1980 who is your broadband provider and how is your main box connected to your router ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for stum1980
I'm using starlink and have 4g as a back up as it's somewhat rural! All have worked with no (significant) issue for months / years. I've had the occasional connectivity issue but nothing a reboot hasn't sorted.
Thanks.
Avatar for stum1980
Also to add, everything is hardwired. Router to box, main box to mini box, access points etc.
