Discussion topic: Connectivity issues
This message was authored by: Emma_C
Connectivity issues
Over the past few months the WiFi keeps disconnecting from my sky Q box, it happens randomly. Sometimes numerous times a day, sometimes it won't happen for a week or so. I also have a mini box upstairs which now disconnects from the main box downstairs so I can't watch tv. Im disabled and struggle to go up and down the stairs to reconnect and reboot. I've tried all the online helps and nothing works. I havent changed my set up. Its very annoying as I was convinced on my last phone call to sky to upgrade my WiFi and  now this is happening. The WiFi never disconnects from other items like phones, iPad etc
This message was authored by: Addie15
Re: Connectivity issues
This message was authored by: KShetty
I have had the issue with my Sky Q box ever  since I switched over to EE BB from Sky.
I scoured through various online forums but without much success.
I do think I have now found a stable solution that works.
Caveat - I have an EE SmartHub Wifi Hub
Go to Hub Manager typing this in your web browser https://192.168.1.254
Enter the admin password supplied with the Hub
On the Hub Dashboard screen, select Wireless => Change Settings (on the top of the screen)
You shall now see a screen with Main and Compatible WiFi as toggle options
Select Compatible WiFi, turn it to ON
The Network name should automatically have a -COMP at the end
I kept Security setting as WPA2-Personal
Security Password is upto you, I kept the same password as the Main WiFi
WPS is set to ON
I enabled the 2.4 GHz channel only
Keep the the 5 GHz channel disabled
Click on Save and return to the Dashboard screen
Now go to the Settings => Network Connection => Network Setup on your Sky Q box
Select the Wireless netwok with the -COMP at the end & enter the password
Once connected , you should be good to go.
Note - I did not change any settings on the Sky Q box by enabling the secret menu pressing 001 when on the Settings menu
