Discussion topic: Connection
Message posted on 29 Sep 2026 12:50 PM
Connection
My sky tv box wont connect to my internet i have tried loads
Message posted on 29 Sep 2026 01:30 PM
Re: Connection
Hi @Stevenr9 Is it a third party router or a Sky router, in which case which one?
Message posted on 29 Sep 2026 07:45 PM
Re: Connection
Hi @Stevenr9
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max Router) then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
