2
This discussion topic has been answered Discussion topic: Connection
This message was authored by: Toon+Rob
Connection
My sky q box connection to the Internet (not with sky for Internet) keeps dropping out...any suggestions?
This message was authored by: Quoman7 Answer
Re: Connection
Hi @Toon+Rob Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Re: Connection
Avatar for Toon+Rob
Re: Connection
That seems to have sorted it! Thank you
