Discussion topic: Connection with sky q
Message posted on 23 Jul 2024 12:51 PM
Hello. I'm not able to receive Sky channels in the 2nd room. I have a box but still unsuccessful.
Message posted on 23 Jul 2024 01:01 PM
Re: Connection with sky q
Hi @Bmg1
Reboot the mini as above.
