Discussion topic: Connection issues
Message posted on 02 Jun 2023 10:36 AM
Connection issues
The last 3 nights I've had to reboot my main sky q box and 2small boxes in different rooms it was saying a connection problem. I'm also not able to get Netflix on the 2 small boxes
Message posted on 02 Jun 2023 11:54 AM
Re: Connection issues
@cecelia01 wrote:The last 3 nights I've had to reboot my main sky q box and 2small boxes in different rooms it was saying a connection problem. I'm also not able to get Netflix on the 2 small boxes
Have you re-started your internet router? Netflix comes via that
Message posted on 02 Jun 2023 12:15 PM
No I will and see how it goes
thanks
Message posted on 02 Jun 2023 01:58 PM
Still no Netflix on my 2 small boxes in the bedrooms but can get it on my main sky Q box
Message posted on 02 Jun 2023 02:15 PM
Hi @cecelia01
Try a Reset Settings in the main Q box hidden menu.
Message posted on 02 Jun 2023 05:56 PM
Can someone phone me as I now have no tv on my main sky q box as the remote will notnoair with the tv after resetting it
Message posted on 02 Jun 2023 06:37 PM - last edited: 02 Jun 2023 06:49 PM
Hi @cecelia01
The Qbox needs to be on with green led.
If the remote dos not switch the box on press the Standby button on the front right of the Q box (the Amber led).
Thn Carefully follow the instructions.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Edit.
Just be aware you not contacting Sky directly here as this is a customer forum where members try to give help.
