Discussion topic: Connection issue for multi room box
Message posted on 30 Aug 2024 11:27 AM
Every Evening after midnight my multi room box upstaires wont connect to my Sky Q box downstairs and then when it is connected my internet keeps dropping out it is so intermitent
I have been with SKY over 5 years but this has been going on for months and I am ready to leave I pay alot to be with SKY i should be able to watch TV whenever I like
Message posted on 30 Aug 2024 01:35 PM
Re: Connection issue for multi room box
Hi @Nicola1211
First check that all your Q boxes are in the same Standby mode. Note that ECO setting shuts the boxes down in the early hours.
https://www.sky.com/help/articles/using-the-standby-settings
Then
Try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
