Discussion topic: Connection error
This message was authored by: Fredbo
Connection error
My Sky mini box keeps showing a connection error on a blue screen any suggestions?
Re: Connection error
Hi @Fredbo
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
