Discussion topic: Connection Issues
This message was authored by: CarolineBroderick
Connection Issues
My connection to my BT router has started to drop out continually.
Smart set up is disabled on the Hub Manager so there's no conflict there.
I've reset the network settings multiple times and the box connects for literally 30 seconds and then drops out again.
I've updated the software on the box too
Any other ideas?
Re: Connection Issues
Any other ideas?
Hi @CarolineBroderick
Assume you are carrying out a Network reset and using the router SSID and password of the router 2.4 Ghz band.
After the box is back up and running carry out another Network reset
This message was authored by: dillonwilliams
can you sort it out it is still conected  but youtube is not working propally and make is really fast
make it really fast on youtube
