Discussion topic: Connecting sky q to a CRT tv - adapters required
This message was authored by: Riojahouse
Hi - I am looking at getting sky Q, but I have a CRT TV, which only has scart. Are there cables available to connect the box to the tv and it works correctly? You can't speak to sky customer services. And I don't want to order it, and it does not work.
the picture on my CRT tv is so much better than any led tv I've seen and it doesn't damage your eyes which is why I've kept it, just incase anyone wondered why I still have one. Thanks for any help. Phil
Re: Connecting sky q to a CRT tv - adapters required
hi @Riojahouse
Dont know what led TV's you have seen but picture quality isn't going to be as good on a CRT TV.
If they are small  sets you may not see any difference but CRT is SD resolution at best.
Sky Q output is copy protected and is unlikely to work through HDMI to Scart converters.
Apart from this the Quality would be abysmal even if it was possible.
