Discussion topic: Connecting Sky Mini Box?
This message was authored by: Mike136
Message posted on 22 Feb 2024 01:56 PM
Can you connect a Sky Mini box using a Cat5e cable via an unmanaged POE+ switch withouit damaging the mini box itself? my currect set-up uses a unmanaged switch and works fine but I have to re-route the cable.
Find out more
Message posted on 22 Feb 2024 02:25 PM
Re: Connecting Sky Mini Box?
Shouldn't be a problem: a Q Mini has no PoE capability so will just ignore the power coming over the ethernet cable.
